Mehdi Saloo
Hello Reno,
Thanks ever so much for your help, I really appreciate it.
I used consistency checking with 4 cores by using ncpu=-4 and SMP single-precision solver. In that case, repeated runs then produce the same results.
I also tried with a double precision solver and ncpu=-4. In that case, repeated runs produce the same results as well, although it is significantly different from the SMP single-precision solver.
Therefore, both single and double precision solvers give me consistent results but there is a significant difference between them. I wonder what the benefit of a double precision solver is and if it leads to better and more accurate results.
I would appreciate it if you could give me some advice.
Thanks in advance.
Mehdi
