August 1, 2023 at 10:27 am
Boundary Conditions: At inlet, the fluid (air) is flowing at 0.5 mach speed with 27 degree Celcius as its temperature. On rod boundary walls, the temperature is 300 degree celcius. The meshing is done in such a way that Conjugate Heat Transfer Occurs and body gets cooled downn by air flow. But results become constant 1 second air flow time and no matter how much time I set as air flow time in transient analysis, the results remain the same.
