Please look very carefully at what you're modelling and setting. The reverse flow occurs for a reason, which is linked to inflow, gas density change (and/or condensation) and outlet & operating conditions. Assuming the mesh is good and the solution converged it's likely that the result is correct for the defined conditions.
