August 2, 2023 at 5:50 am
/ Express onboarding limitations
Limitation 1:
- If an AWS account has a non-default region enabled, Express setup will fail. To see which regions are enabled by default, go to the Regions and endpoints table in the AWS documentation and review the ‘Active by default’ column. (871255)
Limitation 2:
- When Ansys Gateway powered by AWS is set up using the Express setup option, a Virtual Private Cloud (VPC)/subnet is created in every region. The intended behavior is to only create a VPC/subnet in the region selected during setup. (863830)
