Hello Kevin Gnanaraj,
Please find the following reference which describes the optimal way to import the external loads on the model in Ansys Mechanical. Please ensure you select the desired load from the drop-down menu to import the respective load.
Importing Loads (ansys.com)
Data Transfer Mesh Mapping (ansys.com)
If you have the load data ready, another approach would be using External Data, where you can define the load values with the xo-ordinates in an Excel or text file.
External Data (ansys.com)
Also, please find some of the system coupling tutorials which will provide better insights on Force Mapping-
Transcript and Log File (ansys.com) (Please refer to the section of Mapping Summary)
Examine Force Mapping (ansys.com)
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
