Sahil Sura
Hi Kevin,
Here's how you can access the Ansys Online Help from within the Ansys Student products:
  1. Open Ansys Workbench (or any other Ansys product) and go to Help > Ansys Workbench Help. A browser window will open.
  2. Copy the link to the Ansys Online Help from the post on the Ansys Learning Forum.
  3. Paste the link into the address bar of the browser window opened in Step 1, and you'll be able to access the desired page.
Would you please provide some more details on the process which you're following to import the force data, is the data an experimental one or from an FE model?
If seen from the image, there are certain forces that have been imported, thus if the input data is in the correct format, all the points can get imported at the requested locations.
You can also check the efficiency of the imported data for the FE model via the transcripts to ensure a maximum of your input data is reflected in the given model.
Hope this helps!
Thanks,
Sahil
