Adriana Pinto
Hello Federico,
Thank you for your attention. I am simulating a sloshing case, where I have the tank filled with water. I want to measure the damping so for that I need pressure charts. I am measuring that pressure on the basis of the tank.
The hydrostatic pressure is calculated by the formula where you use the density and height of the liquid.
