Hi Anoush,
It is mostly because of the gap present between both the parts which are in contact. Can you try to use a small stabilization damping value(maybe 0.05 or 0.1) and then try to run? Also, increase the number of substeps under the analysis setting.
Thanks,
Akshay Maniyar
