August 4, 2023 at 8:27 am
Hi Akshay,
First thanks for you suggestions, I did utilise a smaller stabilization damping value as recommended and I got a fully-converged solution. But I do wish to know what are effects of this factor on contact forces between faces (ring-wire interface).
Question: Also with current pinball-radius (0.5) I could not seeing any ctonact between inner ring face and wire outer face but still the deformation of wire occurs. Please suggest some contact settings on these issue. (attached picture)
Thanks for your assistance.
