Amirali Atrli
@Lito
Thank you for your response! I need to run the API from the terminal, since I am working on a ssh server, and plan to detach the screen after running the API code. That being said, I believe the problem is not from the API code. I tried running the ../lumerical/v/bin/mode-solutions using the terminal, and it again gets stuck on verifying the license. The mode software works fine, though, when opened using the launcher.
It’s also worth noting that my API worked for multiple times, before running into this problem.
