@peteroznewman Thank you Sir for your response.
Yes Sir, it is indeed related to my doubt.
Is it possible to imitate the surface area regression simulation as discussed in above paper using Ansys tool.
I mean, we just need to give the input parameters, such as burn rate and geometry. And we will get the desired output parameter (Surface Area Vs Web Thickness).
