Azmin Zamsanirani
Thank you, It is currently functioning; however, the coordinates' initial values after evaluation will consistently be in inches ("in"). The problem arises when opening ANSYS Mechanical with the unit system set to another unit. For example, if your current unit is set to "meters," and you evaluate a coordinate that is originally in inches (e.g., 0.2 inches), the software might display it as "0.2 m," which is meters. The only way to make it work as it should currently is to set the units in inches before evaluating the result.
