felice_lucivero
Yes, I am selecting all inlet/ outlet boundaries. Here is the residual plot:
Do you suggest to keep on iterating?
I actually tried to modify the mesh grid in order to avoid reversed flow, but this latter is still pulling up. May it be a good choice to check the "Prevent reversed flow" slot when I set the outlet bc?
I deactivated mesh adaption.
