Dan Dv
Hello Alexandre ,
That errors state that there are two eye source components on your schematic that don't have bit patterns set. Click on the proprities for those components, select hte "Bits" tab and the click on the box next to the "Bit Pattern" property to bring up the form to specify the bit patter for those sources. If you provide a valid setting in that form, it should get you past that error. Please let me know how it goes.
Best regards,
-Dan
