FlorianD
Hello Mike,
I m also modelling a structure subjected to gravity, hydrodynamic pressure and an additional constant force like yours and I m facing the same problem. It's as if the only load applied is the hydrodynamic pressure (coming from the hydrodynamic diffraction module Aqwa) and the others are ignored.
Did you find a better way to link Aqwa to a static structure module than using to static modules as you propose ?
I admit that it s an old post but your help would be very grateful if you found something !
Thanks in advance
Florian
