Caleb Wood
Hi, apologies for the late reply. I have since been able to model the wave tank but now there appears to be another issue, which is the amount of particle mixing. With the piston (wave maker) deactivated, the only load which the particles are subjected to is a gravity loading, applied with the LOAD_BODY_Z keyword. In my mind, if there are no loads directly applied to the water within the tank then there should be no particle movement, but thats not the case. The particles appear to move spuradically and I do not know why. I have attached screenshots as well as my keyword input file (note that the piston is active in this file) to illustrate this. If you know how to correct this issue I would greatly appreciate a response. Also, please ignore part #6 contained in the file, it does not make contact with anything and is only there to serve as a visual aid on the wave height.
IMAGES WITH ONLY GRAVITY LOADING APPLIED
KEYWORD INPUT FILE
$# LS-DYNA Keyword file created by LS-PrePost(R) V4.9.12-16Dec2022
$# Created on Aug-8-2023 (13:38:55)
*KEYWORD
*TITLE
$#        title
LS-DYNA keyword deck by LS-PrePost
*CONTROL_BULK_VISCOSITY
$#      q1        q2      type     btype    tstype
     0.0011.0000E-12         1         0         0
*CONTROL_SPH
$#    ncbs     boxid        dt      idim   nmneigh      form     start      maxv
         1         11.00000E20         3       500        15       0.01.00000E15
$#    cont     deriv       ini     ishow     ierod     icont     iavis     isymp
         0         0         0         0         0         0         1       100
*CONTROL_TERMINATION
$#  endtim    endcyc     dtmin    endeng    endmas     nosol
      15.0         0       0.0       0.01.000000E8         0
*CONTROL_UNITS
$#  length      time      mass      temp
m         sec       kg        k
*DATABASE_BINARY_D3PLOT
$#      dt      lcdt      beam     npltc    psetid
      0.01         0         0         0         0
$#   ioopt      rate    cutoff    window      type      pset
         0                                       0         0
*BOUNDARY_PRESCRIBED_MOTION_SET_ID
$#      id                                                               heading
         0Piston Motion
$#    nsid       dof       vad      lcid        sf       vid     death     birth
        11         1         2         2       1.0         01.00000E28       0.0
*LOAD_BODY_Z
$#    lcid        sf    lciddr        xc        yc        zc       cid
         1      9.81         0       0.0       0.0       0.0         0
*PART
$#        title
SphNode
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         1         1         1         1         0         0         0         0
*SECTION_SPH_TITLE
Water
$#   secid      cslh      hmin      hmax    sphini     death     start   sphkern
         1       1.3       0.2       2.0       0.01.00000E20       0.0         0
*MAT_NULL_TITLE
Water
$#     mid        ro        pc        mu     terod     cerod        ym        pr
         1     997.0     -10.0     0.001       0.0       0.0       0.0       0.0
*EOS_MURNAGHAN_TITLE
Water
$#   eosid     gamma        k0        v0
         1       7.0   65000.0       1.0
*PART
$#        title
Piston
         4         2         2         0         0         0         0         0
*SECTION_SHELL_TITLE
Piston
$#   secid    elform      shrf       nip     propt   qr/irid     icomp     setyp
         2        16       1.0         2       1.0         0         0         1
$#      t1        t2        t3        t4      nloc     marea      idof    edgset
       0.2       0.2       0.2       0.2       0.0       0.0       0.0         0
*MAT_RIGID_TITLE
Piston
$#     mid        ro         e        pr         n    couple         m     alias
         2     100.0   20000.0      0.25       0.0       0.0       0.0
$#     cmo      con1      con2
       1.0         5         7
$#lco or a1        a2        a3        v1        v2        v3
       0.0
*PART
$#        title
Container
         5         2         4         0         0         0         0         0
*MAT_RIGID_TITLE
Container V2
         4     100.0   20000.0      0.25       0.0       0.0       0.0
$#     cmo      con1      con2
       1.0         7         7
       0.0
*PART
$#        title
Wave Height
         6         2         4         0         0         0         0         0
*HOURGLASS_TITLE
Water
$#    hgid       ihq        qm       ibq        q1        q2    qb/vdc        qw
         1         11.00000E-6         0       1.5      0.06       0.1       0.1
*MAT_RIGID_TITLE
Container
         3     100.0   20000.0      0.25       0.0       0.0       0.0
$#     cmo      con1      con2
       1.0         5         7
       0.0
*DEFINE_BOX
$#   boxid       xmn       xmx       ymn       ymx       zmn       zmx
         1      -1.0      12.0      -1.0       1.0      -1.0       2.0
*DEFINE_CURVE_TITLE
Gravity
$#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
         1         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 1.0
               100.0                 1.0
*DEFINE_CURVE_TITLE
Piston Motion
         2         0       0.6 0.0795775       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
                 1.0                 1.0
                 2.0                 0.0
                 3.0                 1.0
                 4.0                 0.0
                 5.0                 1.0
                 6.0                 0.0
                 7.0                 1.0
                 8.0                 0.0
                 9.0                 1.0
                10.0                 0.0
                11.0                 1.0
                12.0                 0.0
                13.0                 1.0
                14.0                 0.0
                15.0                 1.0
                16.0                 0.0
                17.0                 1.0
                18.0                 0.0
                19.0                 1.0
                20.0                 0.0
                21.0                 1.0
                22.0                 0.0
                23.0                 1.0
                24.0                 0.0
                25.0                 1.0
                26.0                 0.0
                27.0                 1.0
                28.0                 0.0
                29.0                 1.0
                30.0                 0.0
