August 8, 2023 at 10:57 pm
I think the problem is with spaceclaim, because it is not keeping the constrains in the sketch.
The geometry should be an angle with both sizes of the same length and same thickness in both sides. The design points (inputs parameters) are the side length and thickness. But in further design points the sides are not equal, not a 90 degree angle between sides, not the same thickness.
