bbcn
Hi again,
I was able to patch the zone starting from Iteration number 1 by using the command text below:
/solve/patch water fluid (fluid-surface_body) mp 0
The command executes once the analysis is run and removes the need to patch manually through initilization window.
Thank you for your help.
Babacan
