It usually means there's a blank field somewhere, ie something is missing from the set-up. Check the remainder of the panel, but there is a slight chance you've turned something on/off earlier in the set-up and corrupted a value call in the GUI. See if turning some of the options on/off clears the issue.
The changed settings report, Input Summary > List Changes can help if you look for empty fields.
