August 9, 2023 at 2:09 pm
Hi Savino,
You installed an ISO image right?
Can you please extract the file and then point the setup to that extracted file?
Please see if these links helps 4.1. Downloading the Installation Files (ansys.com) 3.1. Downloading the Installation Files (ansys.com)
Please confirm if you are following these steps:
• Windows - Extract the contents of the ISO file to a temporary directory, using an archiving utility such
as Winrar, Winzip, or 7zip. Run setup.exe from the top level folder.
• Linux - Mount the image, using "mount -o loop -t iso9660 filename.iso /mnt/iso" command. Run
"./INSTALL" from the top level folder
