August 10, 2023 at 12:29 am
There is no published API for this. You have to do it through a call to the GUI command. Unfortunately, the recorded commands that create a datum line won't associate the datum with the selected edge, so it can't be pinned. So you also have to use a GUI command to create the datum line.
from SpaceClaim.Api.V23 import Command
selection = EdgeSelection.Create(GetRootPart().Bodies[0].Edges[462])
selection.SetActive()
Command.GetCommand("CreateDatumLine").Execute() # the axis created will automatically be selected
Command.GetCommand("PinDatum").Execute()
