Kaushal Sawant
@peteroznewman, thank you for your confirmation. The latest analysis (stress with 25.993 MPa) had the end time as 0.025s. I increased the end time with the same reason you quoted. Moreover, if I go on increase the end time, the maximum clock time goes very high. Due to limitations of license usage I have limited it to 0.025s. The stress was damped after achieving the peak value.
