Mohammad Haikal Md Fouzi
Hi Mangesh,
Thank you for pointing out that. Another question that I have is what is the default number of cpu requested if i set the component execution mode to be serial?
I've faced a weird issue where I set the it to serial and submit the project to a RSM queue that have 256 cpu cores (I was expecting that it will use all the 256 cores to solve) but it seems like only 2 cpu cores were requested and causing my job submission to be rejected. How do I ensure serial component execution use all the cores available in the RSM queue?
Kindly refer to the attached screenshot.
