August 10, 2023 at 9:25 pm
I've recently begun using the water corrosion prediction tool for simulating strong acid conditions. I'm curious about its applicability for a pH of 9.
After running simulations for a 1-hour duration, I've noticed both positive and negative results in the total surface corrosion rate. Could someone kindly explain the meaning of the positive and negative values? I would greatly appreciate any insights. Thank you
Fang
