”MATID” indeed refers to the material ID. It is a numerical identifier assigned to different materials in a finite element analysis (FEA) model. Each material in the model is assigned a unique MATID, allowing you to specify material properties and behavior for different parts of the structure.
To find the material IDs in your specific model, you’ll need to check the materials assigned to the elements or components.
