August 11, 2023 at 8:28 am
You are right, thank you. Since all of my parameters change within vertical direction I removed horizontal and tangent constraints and I was able to update the geometry manually. Below is the new geometry and the mesh:
However, I'm not able to open the setup through WB. Fluent opens and tries the load the geometry but then closes and I recieve the following error:
My named selections remains healthy if that matters. Let me know if you require more info.
Thank you.
