OK, continuity will be the key here. Add a volume monitor of VOF mass in the domain and see how that looks. I suspect it'll not be a flat line, and then look at the mass of oil in & oil out as two extra monitors. If you take the mass variation of oil, and know the heat capacity what sort of temperature change would you expect?
