August 14, 2023 at 11:14 am
Hi Rob,
Thanks for the quick reply. I haven't used the exact monitors you mentioned and I will start a simulation with these today. In the meantime, I can show you a few similar monitors I have been using to check continuity.
All the graphs below are for the last 2000 iterations.
- total-heat-transfer-rate (W) - does not take the heat source (23W) to account
- total-mass-flow-rate (kg/s) - All input minus output fluid (oil and air), maximum mass imbalance is 8%
- avg-vf-oil-in-fluid - volume average of the volume fraction of oil in the fluid domain
- winding-temp (k) - Area weighted average of the winding temperature
As you can see the temperature value does not change a lot. I do not fully understand this part of your answer "If you take the mass variation of oil, and know the heat capacity what sort of temperature change would you expect? "
