Ram Gopisetti
Hi
with define curve should have negative and positive side of the curve, i.e., from compression to tension and an 0,0 point
If you don’t have tension data, try to extrapolate it, assuming that you are working on compression loading only.
Can you clarify on the second point
cheers, ram
