javat33489
Thanks for the answer. I understood you. I did so. Included MSL in the settings and the type of MPP:
I also set the time I needed to 1 sec:
I also had to increase the endmass due to a low mass error:
I tested it on two samples, flat and round, and this is what I came up with.
When the drill was moving, the nozzle simply broke off and deformed:
The round sample went well at first, but then it gave an error and the calculation stopped:
