Hi, the Ansys Academic CFD Research license alone gives you access to run simulation on up to 4 cores. This is the capability of the base license itself. If you want to utilize more than 4 cores, you will need HPC licenses. HPC Workgroup 128 will effectively give you access to utilizing 128 cores on top of the 4 base cores. This means you can run a simulation on 132 cores at a time if you fully utilize your HPC workgroup + the CFD research base license.
