Tarun Maddipatla
  1. Solution Setup - Modal
  2. Top and bottom conudcters - given perfect E field excitation. The microstrip and the layer below the substrate are not assigned any material. They are simple rectangle objects
  3. Mesh settings haven't been provided any. I am simulating the above micrsotrip line at 60GHz frequency. My laptop has 4 cores and 4GB RAM.
  4. The substrate is made of SiO2 (er = 4) and width of the microstrip line (top layer) is 5.0989045mm. Please check these details and help me fix this issue
