Please can you post some images, phase, pressure and velocity would be helpful. Depending on volume fraction etc you can get liquids collecting and then dropping down in a porous zone in the experiment and gas then diverts up due to zone pressure effects. If the porous zone is very thin with low resolution in the CFD model you may not see that.
I assume gravity is pointing in the correct direction?
