Gaby Saad
I used the material parameter values of page 165 of the book of Potts and Zdravkovic, to simulate what is shown in Fig. 1 (below) for validation purposes:
-          κ=0.025
-          v=0.25
-          ah0=200/2=100kPa
-          e0=v1=2.67-1=1.67
-          λ_f=0.181
-          Mc=0.797
-          Initial stress state -200.1kPa, -200.1kPa, -200.1kPa
(inis,set,dtyp,stre
inis,defi,all,,,,-200100,-200100,-200100,0,0,0)
-          Ks=0.78
using prescribed nodal displacements:
and the resulting deviatoric vs axial strain graph turned out the same:
I tried simulating cam clay with a simple 4 element test model to see if the solution will converge (having only solid185 element) with instate command and it did not work, the error still appears:
 The material solution failed for element “x” with material “x”
(NOTE: the inistate command applied to my model is:
inis,set,data,func
inis,set,dtyp,stre
inis,defi,all,,,,LINY,0,-17651.97,0,-17651.97,0,-17651.97,0,0,0,0,0,0        The soil density is 1800 kg/m3 and the gravity is applied in step 1 at time 0 and 1s is 9.80665 m2/s)
 Any suggestions on why this error is appearing? Your help is appreciated.
