August 15, 2023 at 5:30 pm
Thanks for the fast response! I tested it, and indeed the EME propagator does run when you perform a sweep, even if you don't put it in the analysis script. I did not expect that behavior, that is a big help! Is there anywhere in the documentation detailing what commands are/aren't design to be used in the 'model' analysis script, and what runs automatically when a sweep is performed?
