mohsen ab.1999
Hi
i also use aqwa co simulation for simulating floating offshore wind turbine and in the aqwa co simulation setup in ansys rigid dynamic module i have a big problem with uploading the Aero Dyn primary input file and inflow wind input file , it does not work and in extension log file some erorre appear like this :
AqwaCosimulation: Inadequate blade data files (ADBlFile) given in the AeroDyn primary input file (C:\Users\fatemeh.km\Desktop\AeroDyn primary input file.txt)
AqwaCosimulation: Failed to prepare the AeroDyn marker data.
......can you send a  Aero Dyn primary input file sample for me ?
this is my Email :abnmohaen@gmail.com
