Ding HC
Thank you for your reply!
This means that in the UDF definition for the phase interaction of heat transfer coefficient, what I need to return is the effective heat transfer coefficient, which is the product of the volumetric heat transfer coefficient and the interface area. Instead of the Single volumetric heat transfer coefficient introduced and mentioned in the manual earlier, right?
