Simranjeet Singh
Thank you, Rob, for your response.
You’re correct, I haven’t achieved a converged solution yet. In addition to that, I’m observing reversed flows after just 230 iterations out of the total 3000 iterations. Interestingly, the planar 2D simulation doesn’t converge either even when run for 3000 iterations. Nonetheless, it does provide me with some results that I can compare.
