Sahil Sura
Hi Hugo,
So ensuring the material model is right as per your criteria, for boundary conditions you can check the loads are properly scoped and there won’t be any rigid body motion due to insufficient supports.
Checking the contacts, if they capture the required behavior.
A check on the boundary conditions and contacts for a complex assembly can be done by performing a simple Modal Analysis. So if rigid body modes are present, this will indicate an unconstrained model.
If the defined analysis runs perfectly, but you're facing this element distortion or so error, you can go for updating the Substeps/timesteps and other options from the Analysis Settings.
Please find the following resources for further detailing on boundary conditions and contact behavior-
Stress Analysis in Ansys Mechanical | Ansys Courses
Contact (ansys.com)
Hope this helps!
Thanks,
Sahil
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
