javdijaj
I am modeling a complex industrial furnace in a steady state regime.
When I open the case, this appears:
bandwidth reduction using Reverse Cuthill-McKee: 413193/25410 = 16.261
Info: The mesh contains elements that are invalid or of poor quality.
      A different numerical scheme will be applied to these elements,
      which may affect the quality of the solution. It is recommended
      that you consider removing the invalid and poor quality elements
      in the mesh.
      For more information on the invalid and poor quality elements,
      please use the following TUI commands:
      /mesh/check
      /mesh/repair-improve/report-poor-elements.
     materials,
     interface,
     domains,
mixture
     zones,
...... all zones loaded,
Done.
When I apply all the BC's and I click on initialization, this appears:
Node 14: Process 13064: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 39 PID 11916 RUNNING AT DESKTOP-K29GIF8
=   EXIT STATUS: -1 (ffffffff)
 The fl process could not be started.
