javat33489
Hello. I tested the dynamic grid by adding a rotor and a stator. I made 5 options but it didn't work for me. I'm surprised why it doesn't work. Somewhere an error. Help me please.
I made a selection of faces for the shoulder blades.
And this is how the wheel originally looked, before extracting the volume around it:
I also made the rotor and stator faces:
Next, I made 5 variants of tests.
1.Blades rotating along the X axis. For the inner and outer blades, the same settings:
Stator and rotor with the same settings without rotation, and the passive checkbox is also enabled:
The area does not rotate, you can see it in my rotation sensors and in the animation.
2.Blades rotating along the X axis. Settings as in 1.
Stator and rotor with the same settings without rotation (settings as in 1). The stator is passive. Rotor is on (not passive).
The area also does not rotate.
3.Blades rotating along the X axis. Settings as in 1.
The stator is passive. With settings without rotation.
Rotor passive with rotation settings:
4.Blades rotating along the X axis. Settings as in 1.
Rotor is on (not passive), but with rotation settings.
5.I tried to remove the rotor surfaces from the dynamic mesh settings altogether.
There were blades rotating along the X axis. The settings are the same as in 1.
__________________________
During the calculation, I received such messages:
