Jian Liu
Thank you very much for visiting!
1.To be precise, the air domain is mobile. Above is the gas action area, below is the molten matrix, and the laser acts between the two phases.
2.VOF and melt solidification models were used in the simulation.The density, thermal conductivity and specific heat capacity parameters of the set material are set to fixed values (divided into two types: before and after the melting temperature, and the paste zone is a piecewise-linear curve),and the base material only sets the viscosity of the melted fluid.
Is it possible to stop the liquid phase moving by setting the melting point value and the viscosity of the melted fluid?
Thank you very much for your help!
