Assuming heat going in is the same as heat coming out and residuals are good then the model is likely correct. Whether the boundary conditions you set are appropriate is a different question, and one I can't easily answer.
The model with the conformal mesh is the one I'd focus on. How does the heat flux in the full model compare for each surface to the simple model?
