Robert Mehlig
So like this?
cmsel,a,P425
cmsel,a,P426
cmsel,a,P427
cmsel,a,P428
cmsel,a,P429
cmsel,a,P430
cmsel,a,P431
cmsel,a,P432
cmsel,a,P433
cmsel,a,P434
cmsel,a,P435
CM,POINTS_COMBINED,node
outres,erase
outres,all,none
outres,nsol,all,POINTS_COMBINED
ALLSEL
! *********** WB SOLVE COMMAND ***********
! check interactive state
*get,ANSINTER_,active,,int
*if,ANSINTER_,ne,0,then
/eof
*endif
solve
/com *************** Write FE CONNECTORS *********
CEWRITE,file,ce,,INTE
/com,****************************************************
/com,*************** FINISHED SOLVE FOR LS 1 *************
/com,******************* SOLVE FOR LS 2 OF 2 ****************
/com,*********** Set Force Without Surface Effect Elements "T1 Pin" ***********
sfedel,_CM187_3,3,pres,all
sfedel,_CM187_4,4,pres,all
sfedel,_CM187_5,5,pres,all
sfedel,_CM187_6,6,pres,all
nsel,all
esel,all
/nopr
/gopr
autots,off                 ! User turned off automatic time stepping
deltim,8.333e-007,8.333e-007,8.333e-007
time,7.5e-004
timint,on                  ! Turn on time integration effects
outres,erase
outres,all,none
ALLSEL
solve
/com,************ FINISHED SOLVE FOR LS 2 **********
