Alwan Hibatullah
where is the destination of the link? because it takes an account number but I use ansys sutdent
so if I give a constant flux to the stator (see picture above), where will the heat flux propagate to the helical coil right? so that the helical coil will also be exposed to a constant flux with a greater value than the stator because of its smaller surface. then with the same heat flux, why is the temperature value of the helical coil in the full model and the simple model different between the two modes?
