You can set the temperature/pressure based on what the panels allow you to do: check the options.
Remember, if the pressure at the inlet is higher than in the tank the gas will expand on entering, that may explain the cold spot?
Fluent will solve the same equations regardless of the speed; it's whether you pick suitable settings to cover the whole domain that will effect the result.
