M Usman
I previously tried applying the temperature on wall but Conjugate Heat Transfer does not happen as result become constant. And then I got a suggestion from here that I should patch the temperature on the body and that worked and only because of this I have to create a very thin cylinder otherwise in actual, I only had to apply the temperature on the inner wall of the barrel.
