August 28, 2023 at 4:43 am
I have tried this approach as well but when I display the contours after initializing, the temperatures on the bodies do not get updated but when I patch the temperature, contours get updated. Also the recommendations you wrote to avoid the floating point exceptionor divergence worked in one case but when I slightly changed the geometry, the same error is appearing again. I have tried changing method and oter parameters but nothing worked.
