Kushal Joshi
Thank you Mr. Doyle.
Yes, I use a tet mesh and I can interpret the max radius value from the size. But my main concern is how can I control the radius? I want it to be as less as possible for the max member size constraint. For example in my case, even though the max element sizing I specify is 5mm in the local size controls, the radius is around 8-9mm. Is there anything else I need to do in mesh controls to reduce this?
Kushal
