Masooma_Qizilbash12
yes, I used the transient settings because the speed of the impeller is 5000 RPM. Just changed the settings a little by putting turbulent Kinetic Energy and dissipation rate from 0.9 to 0.5 and pressure =1,  Bin 0,1,2,3,4,5. All bins have 0 value except for bin 3. bin 3=1. The trend is the same here in the monitors. Also attached is the population balance model settings used.
thank you for the help
regards,
masooma.
